Refrigerators Logo
A
Alan Monzo Posted on May 30, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model DIM32D2BSSPR Ice Maker. After several cycles, unit shuts down and the 3 size selector lights start flashing. If I hold down power button, unit resets and starts working.
Adviser101
Level 2:
Sergeant:
  • Expert 130 Answers
  • Posted on Jun 19, 2023
Adviser101
Expert
Level 2:
Sergeant:
Answers
130
Questions
0
Helped
6934
Points
563
It seems that you're referring to an issue with the DIM32D2BSSPR Ice Maker model. When the unit goes through several cycles, it shuts down and the three size selector lights start flashing. Holding down the power button allows you to reset the unit and resume its operation.
Based on the provided information, it appears that there may be a malfunction or error occurring within the ice maker. Here are a few steps you can try to troubleshoot the issue:
1. Check the power supply: Ensure that the ice maker is properly connected to a stable power source. Verify that the power cord is securely plugged in and there are no loose connections.
2. Clean the unit: Ice makers can sometimes experience issues due to debris or mineral buildup. Clean the ice maker thoroughly, including the ice bin, water supply lines, and any filters or screens. Follow the manufacturer's instructions for cleaning and maintenance.
3. Reset the unit: As you mentioned, holding down the power button allows you to reset the ice maker and get it working again. If the issue persists, try performing a factory reset if your model supports it. Refer to the user manual for instructions on how to reset the unit.
4. Contact customer support: If the problem continues to occur despite your troubleshooting efforts, it's recommended to reach out to the manufacturer's customer support or service center. They can provide further assistance, troubleshoot the issue over the phone, or recommend a professional repair service if necessary.
Remember to consult the user manual specific to your model for any additional troubleshooting steps or guidance provided by the manufacturer.
I have a Kitchen Aid under the counter Ice maker. When you power it on it cycles water and then the power button light flashes several times and powers off.
If your KitchenAid under-counter ice maker is cycling water but then powers off with the power button flashing several times, there may be a few possible causes. Here are some steps to troubleshoot the issue:
  1. Check the water supply: Make sure that the water supply line is properly connected and the water is flowing to the ice maker. If the water supply is blocked or not reaching the ice maker, it may not be able to function properly.
  2. Clean the condenser coils: Dirty condenser coils can cause the ice maker to overheat and shut off. Make sure to clean the coils regularly to prevent this issue.
  3. Check the drain pump: If the drain pump is not functioning properly, the ice maker may shut off to prevent water from overflowing. Check the drain pump for any clogs or damage and replace it if necessary.
  4. Check the water inlet valve: The water inlet valve is responsible for letting water into the ice maker. If it is not functioning properly, the ice maker may shut off. Test the valve for continuity using a multimeter and replace it if necessary.
  5. Check the control board: If all other components are functioning properly, the issue may be with the control board. Test the control board for proper voltage and replace it if necessary.
If these troubleshooting steps do not resolve the issue, it may be necessary to call a professional technician to diagnose and repair the problem with your KitchenAid under-counter ice maker.
1helpful
My PT Model IM-600 US ice maker makes cubes but continues to freeze on the ouside of the cube tray blo th cubes from falling into the bucketwhat is wrong.
cubes set too large
Adjusting the Ice Cube Size: 1. Press and hold the "Adjust" button for approximately 3 seconds until the Green Indicator starts blinking, release the button. The unit is now in Ice Adjustment mode. 2a. Press the "CLEAN" button to decrease ice cube size. The Red Indicator will flash as you lower in size and will blink when you have reached the smallest possible setting. 2b. Press the "MODE" button to increase ice cube size. The Yellow Indicator will flash as you increase the size and will blink when you reached the largest possible setting. After 10 seconds without any operation, the unit will return to the previous mode. NOTE: • During the ice adjustment mode, if the "ICE FULL", "ICE MAKING" and "ICE HARVEST" LED's all blink simultaneously, this means setting is at the regular (middle) size. • When the machine is in the cleaning stage or ice full stage, the ice size cannot be adjusted.
I need help troubleshooting an ice maker
Practical Ice Maker Troubleshooting Tips
www.achrnews.com/.../106192-practical-ice-maker-troubleshooting-tips
Since you're already online, why not visit the ice machine manufacturer's Website and... indicator lights mean with regard to what part of the operational cycle the machine is in, .... that it's the right size and turns in the right direction, and make sure no other appliances .... What does the ice pattern on the evaporator look like?
How To Fix A Refrigerator Ice Maker That Is Not Making Ice ...
removeandreplace.com/2013/.../check-refrigerator-ice-maker-making-ic...
Nov 3, 2013 - Fixing the ice maker on your fridge is not usually a difficult task. ...
2answers
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Ge mongram ice maker blicking clean light
 Whenever the unit has reached a failure mode, the LED will flash, and the unit will shut down. If the failure was caused during a harvest cycle which lasted more than 16 minutes, the LED will remain flashing on & off in halfsecond increments. If the failure is caused by a faulty bin thermistor, (not detected), the LED will remain flashing on & off in 1-second increments. These are the only two failures that cause the unit to reach a shutdown failure mode. x During the Clean cycle, the control board performs the diagnostics first. If the bin thermistor is not detected, the LED will flash two times. This is followed by a 3-second delay. If the evaporator thermistor is not detected, the LED will flash on five times. This will be followed by a 3-second delay. The LED will then come back on, and remain on for the remainder of the Clean cycle, and until the unit is turned back on.
6helpful
3answers
U-line CLR2160 won't go into clean cycle. I hold the power button while pressing the light button 3 times.
I had to hold Power for 10+ seconds (until last "F" flashes, quickly let go of Power, then press and hold it again and while holding it pres the light three times.
The process doesn't follow the manual's instructions at all.
Their older model units with the physical on/off/clean selector switch was much more reliable than their new 2160 with touch screen controls!
1helpful
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
5helpful
2answers
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
GE Profile PDS22SIS ice maker problem
on the ice maker press and hold the size selector. This will put the ice maker into a test mode and it should cycle through. If it doesn't work your problem is with your icemaker.
Sgt 48
3answers
Ice Maker not going through complete cycle
what kind of unit is it? there are several possibilities
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
