I used the flashlight trick and I have menus working, can go to youtube, etc., and the TV sometimes does backlight for a few seconds or even minutes. I used a multimeter for the diode test and the LEDs do light up, with volts from 2.47x to 2.48x. With the LEDs lighting up, would it be the T-con board?
I believe you have some shorted LED lamps on the backlight strips that are causing over current and shutting down the inverter protection circuitry.. New backlights should fix the set
Please try adjusting the brightness on your tv to show more light so that you can view the tv without a flash light. Thank you.
