Televison & Video Logo
A
Anonymous Posted on Aug 05, 2022
75 inch roku tv Standby light flashing 18 times no power up. Bought repair kit from shop jimmy. Replaced 5 different boards. Same problem. Any ideas?
Larry
Level 3:
  • Roku Master 5,042 Answers
  • Posted on Aug 05, 2022
Larry
Roku Master
Level 3:
Answers
5042
Questions
Helped
1241951
Points
18413
Is this a TCL Roku TV? Also what's the model number?
Testimonial: "Its a hisense. I think its the led back light. Did the flashlight test and can see a picture Thanks"
  • Larry Aug 06, 2022
    There is a good chance of it being bad backlights, only thing I'd test before taking it apart is the command that tells the backlight inverter to turn on, look for a pin marked Bl_On you need to see around 3 vdc there, if that's missing look at a main board issue
    BTW this will be on the connector going from the power to main board
I have a 4k, 50in. LED Onn tv, I need to order a power supply, who can you refer me to, so That I may order the part. Thanks, Joey Bush
Shop Jimmy. Tell him we sent you :>)
https://www.shopjimmy.com/
OR
brand-ONN - LCD / LED TV REPLACEMENT PARTS ...
moretvparts.com > ... > onn
ONN ONA65UB19E07 TV LED STRIP M08-TP65030-0601N-4270A. $10.00 ... ONN ONA65UB19E07 TV POWER SUPPLY BOARD PW.168W2.802 / ...
onn tv 50" ' eBay
www.ebay.ca > sch
ONN ONA50UB19E05 TV Repair Parts Kit -Version 3 (SEE NOTE). New (Other). C $65.80 ... ONN 50 Inch Roku 100012585 Tv Stand With 2 Screws ... New Onn 100007147-H / JVC LT-50MAW595 Power Supply (TV5006-ZC02-02) E021M289-T1. Brand New ... Onn ONC50UB18C05 4K LED TV EACDJ6E10 T-Con Board.
Television Replacement Parts: Electronics - Amazon.com
www.amazon.com > Television-Replacement-Parts
Results 1 - 24 of 3000+ - Online shopping for Television Replacement Parts from a great ... LB70006 Replacement LED Backlight Strips (12) for Vizio E70-E3 ... BN44-00808D Power Supply Board Compatible for Samsung ... Stream 4K Video ..
Samsung UN55D6000SFXZA. Upon powering on only flashing red stby light, no screen, back light or sound.
just cause your power supply is tested good doesnt make it good it could be a shorted panel or more likely the leds behind it unplug everything except the remote eye mainboard and buttons from the power supply and see if the light stays on if it does then i would look into the led strips also check the flash's i dont remember if samsung has a set amount of flashes = a code
Samsung LED 60' TV UN60J620DAFXZA not turning on? No red standby light? No backlights?
Did you try repairing the PS with a repair kit first then replace both the boards after that?
1helpful
I have a 46PFL3608/F7 46-inch LED TV, when I plug the TV in it comes on and the blue led below the philips logo flashes 5 times and then the speaker makes a slight pop sound and the set shuts off.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Sony KDF 60WF655 standby/power light blights 10 times then repeat
This is what I found
You may want to have a Tv repair shop look at this .
Standby light flashes 10X
Symptoms / Customer Description
[Primary Symptom Code: 2111 ]
Solution
G1 and G2 boards are ok.
Found Q box was causing loss of DTL MODULE 5v.
Replaced Q box to resolve.
Part #
A1058689A
Top Roku Televison & Video Experts
vince
Paul Carew
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
