When I search for my channels it finds them and then says multiplex needs update.
You have an issue that no one has ever had before. Phone the maker and ask.
https://www.google.com/search?q=konka+tv+wont+stay+on+the+chanels+it+keeps+saying+multiplex+needs+update
............ 0906 0702 0203 0306
................. 0208 0911 0842 0942 0504
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
0906 0702 0203 0306
Direct Code Entry
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
OK.
0906 0702 0203 0306
Direct Code Entry
button.
flashes.
be controlled.
button.
Code Search Method.
the code.
OK
