Problem av
Hello 0906 0702 0203 0306 Direct Code Entry 1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit. 3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes. 4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of Code Search (by Brand) Lets you search for a code for a specific Brand within the Code Library for a particular manufacturer. 1. Turn on the device (TV, VCR, etc.) to be controlled. 2. Press and hold the CODE SEARCH button until the red indicator remains on, then release the CODE SEARCH button. 3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks off once. 4. Press and release the numeric button (0-9) corresponding to desired Manufacturer (see table below). Note, pressing "0" performs a full library search same as Device Library Code Search Method. 5. Press the CHANNEL UP button ((or POWER or PLAY (VCR only)) repeatedly until the device to be controlled changes channel. 6. Press and release MUTE to install
You just buy one Philips Universal Remote Control model number [CL 034]. Your TV, Konka is listed in its codes. The codes and entering procedure are given:-
Codes For Konka:-
................. 0208 0911 0842 0942 0504
the other codes for your brand.
the code.
OK.
