Washing Machines Logo
M
Mary craft Posted on Jan 18, 2022
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power to washer but no action
My series 4000 front washer locks the door, lights come on, timer starts but nothing else. No water, no tumble, etc where do I begin to look for problem source?
Larry
Level 3:
  • Master 5,042 Answers
  • Posted on Jan 18, 2022
Larry
Master
Level 3:
Answers
5042
Questions
Helped
1241910
Points
18413
  • Mary craft
    Mary craft Jan 19, 2022
    Can’t even find that anywhere
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I called in an electrician/plumber - thanks !
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Buttons lit up, washer not going
If nothing works, no water and no motor action, then it sounds like a door switch or door lock problem. Check to make sure door is properly shut and switch is operating.
3helpful
2answers
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Top Washing Machines Experts
john h
