Go to
http://www.manualslib.com
Ultimate manual library.
They have a manual to help you, also , see if your app store has an app for what your needing..
To delete one entry, press MUTE/REMOVE while displaying the number. To delete all number, press and hold MUTE/REMOVE until the screen displays "DELETE ALL?" then press MENU/SELECT.
If you need a manual, you can download one at http://vt.vtp-media.com/ecp/documents/product_Product/85/UserManual/245/6041_Manual.pdf
Before you store a telephone number in memory, make sure the dialing mode is correctly set for the type of service you have. The default dialing mode is tone (touch-tone), so if you have pulse (rotary) service, you must first change the dialing mode. See “To Set the Dial Mode.” The following buttons can be stored into any memory location: 0-9. STORING FREQUENTLY CALLED NUMBERS 1. Pick up the handset. 2.Press the store button. 3. Push the desired memory location button. 4. Press the store button. 5.Use the handset number keys to enter the telephone number (up to 16-digits) and press the store button. 6.Hang up the handset. NOTE: If you make a mistake, use the delete button to delete wrong digits. CHANGING A STORED NUMBER Repeat the storage sequence above. The new number replaces the old number at the memory location. ERASING A STORED NUMBER 1. Pick up the handset. 2.Press the store button. 3.Press the memory location (0-9) to be erased. 4.Press delete for three seconds until the number in the display is erased. 5.Hang up the handset. DIALING FREQUENTLY CALLED NUMBERS 1. Pick up the handset and press the mem button. 2. Press 0-9 for the memory location. The number dials automatically. OR 1. Pick up the handset and press the dial button. 2. Press the review button for the desired memory location. 3. Press the dial button to dial the number. OR 1. Press dial button while the handset is still in the cradle. 2. Press the review button for the desired memory location, lift the handset and the number dials automatically.
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Here are the commands to run the phones memory dial (speed-dial). I have included the instructions for deleting and changing numbers as well. It is listed below. I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number
1. Repeat steps 1 through 4 in Storing a Number in Memory.
2. Press the REDIAL button.
3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number
1. Repeat steps 1 through 6 in Storing a Number in Memory.
2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number
1. Make sure the phone is ON by pressing the TALK button.
3. Press the number (0-9) for the desired memory location. The number dials automatically.
Inserting a Pause in the Dialing Sequence
Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers
1. Press the MEMORY button.
2. Press the desired memory location (0-9).
3. Press the MEMORY button twice to delete the entry.
4. You will hear a confirmation tone.
thank u so much for trying to help. I guess my message wasnt clear enough though. The phone is not storing my "messages", I'm not having a problem with that, I can clear them, no problem. Its the "recent log" under the "add recipients" that does not clear. The "recent log" stores all the numbers you ever text messaged to. I want to clear the #'s that I've text messaged to, not regular calls, thats easy to clear. For some reason this phone stores all the #'s that you text to. If you can figure it out, i'll give u a million dollars!!! just joking of course.
thank u!
