20 Most Recent
Panasonic (KX-TDA0104) (KXTDA0104) Power Supply Questions & Answers
I need new panasonic kx-tda 600 pabx software?
KX-TDA100 Maintenance console found at www.wanetelecoms.comKX-TDA200 Maintenance console found at www.wanetelecoms.comKX-TDA50G Maintenance console found at www.wanetelecoms.comPanasonic Unified Maintenance console Version 7.3 found at www.wanetelecoms.com
6/30/2012 7:18:32 PM •
Panasonic...
Answered
on Jun 30, 2012
I looking for power supply inside the plasma tv.
Just a shot in the dark. Is there possibly a reset button somewhere on the back of the set? Otherwise, follow the power cord into the back of the set. Usually the first thing you'll come to is the power supply.
Good luck.
Jeff
2/7/2011 10:29:09 PM •
Panasonic...
Answered
on Feb 07, 2011
I have a tda100 with
Guessing the dhlc8 is in the optoinal card slot which doesn't work with that card. You can only put the optional base 3 card in that slot which handles some of the auxilary equipment.
12/9/2010 12:36:26 PM •
Panasonic...
Answered
on Dec 09, 2010
Is there an upgrade kit available for Panasonic TV power supply ?
There are a couple of things that could cause this, unfortunately there is no reset for this televisions and it will have an internal failure at this point. I will try to explain the possibilities the best I can.
First you could have a failure in the power supply, we have seen some capacitors fail in your model and cause funky problems like this. If this is the case you could be looking at somewhere around $175-$200 to fix the set. IF the power supply had to be replaced you could be looking at $350
Next could be the main board, this would not be good news because you could be looking at $400-$500 for the repair (I know this is up there in the price range and most likely getting over the cost of a new set)
Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set. The panel in your tv is about $800 just for the part.
Any of these could cause your problem, but it will require troubleshooting to determine the exact cause of your problem. If you have experience, and test equipment and would like to attempt some troubleshooting I will be happy to assist you, however if you do not have equipment or experience then you would need a repairman at this time to get an exact diagnosis. I am sorry that I don't have a quick fix or easy answer for you on this one, it is definitely an internal failure.
And Thanks.
4/13/2010 5:38:10 PM •
Panasonic...
Answered
on Apr 13, 2010
To whom it may concern,
are you using the DXDP feature? If not then you can give DXDP extensios instead of connecting 1 DLC card.
5/6/2009 5:18:52 PM •
Panasonic...
Answered
on May 06, 2009
Kx-tda 600
There may be some issue from the field side. use GDD fuses to protect the system. These are connected in the krone modules.
5/6/2009 4:56:18 PM •
Panasonic...
Answered
on May 06, 2009
Analog card not working in tda100
you will still need to dial a 9 from the phone to get an outside line, or you can program the analog ext to auto dial it for you. If you still can't then it sounds like the phone is in the wrong COS so it doesn't have access to the CO's.
4/18/2009 12:34:13 PM •
Panasonic...
Answered
on Apr 18, 2009
Tda-600
hi,please check the power supply model, and tell me.emilio villa.
2/17/2009 8:42:24 PM •
Panasonic...
Answered
on Feb 17, 2009
