I have a Hisense 50k23dg and the screen was black and I found it had burnt LEDs. I replaced the led strips and now the screen is a blue screen with white vertical lines. The lines fade and move around the screen and eventually the screen gets dark and the vertical lines change colors. I'm assuming my main board is bad but is there a way to test this? Or is it a tcon or power board issue?
Can you take a picture of the TV with a picture on the screen. I suspect you may have damaged the screen when you handled it but can tell more with a pictureCan you take a picture of the TV with a picture on the screen. I suspect you may have damaged the screen when you handled it but can tell more with a picture
You can't post conmments that contain an email address.
The main board and the power supply is bad for your TV and it would be more easier to buy a new TV than to try and fix the current TV that you have and that our TV could of had died on you.
Hello William, for what you say, you have a problem in backlighting
It can be the source that feeds the LEDs or that the lighting LEDs are wrong
the solution, replace the led strips, that do not work,
Correct solution, change all the LED strips of the backlight
I send you a video where they show the procedure
I hope you can solve the problem
Greetings Franco Dosil
Hola William, por lo que cuentas, tienes un problema en la retroiluminacion
Puede ser la fuente que alimenta a los Leds o que los Leds de iluminaci?n est?n mal
la soluci?n, reemplazar las tiras de led, que no funcionen,
Soluci?n Correcta, cambiar todas las tiras de Leds de la retroiluminacion
Te env?o un v?deo donde muestran el procedimiento
Espero puedas resolver el problema
Saludos Franco Dosil
Hello Kenpappas, for what you describe, it would seem like a backlighting problem
questions if you can have a bad led ?, if many times a Led, is the one that proboca the failure
The correct solution from my point of view is, replace, all the Leds
As it is not practical to replace each led in the strips
It is more practical and simple, replace the full strips of leds
I send you a video, in which they show, the procedure of replacing the LED strips on a Hisense TV
Hola Kenpappas, por lo que describes pareceria problema de retroiluminacion
preguntas si puedes tener un led mal?, si muchas veces un Led, es el que proboca la falla
La solucion correcta desde mi punto de vista es, reemplazar, todos los Leds
Como no es practico reemplazar cada led en las tiras
resulta mas practico y sencillo, reemplazar las tiras completas de leds
Te envio un video, en el cual muestran, el procedimiento de reemplazo de las tiras de Leds en un televisor Hisense
Espero que puedas resolver el problema
i assume this is an lcd, not led tv. the flourescent backlighting's inverter unit has gone out. its usually a seperate ic card, so it is repairable, if you can source the part cheap
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
Hi check the links hope it will help you
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience http://electro-medical.blogspot.com/
If you wish to get some details; visit the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.//
