Car Audio & Video Logo
Hasaan Aslam Posted on Aug 04, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 4 digits issue in clarion nx513. i put 0000,1234,1111,5555 but my issue hadn't resolve.what can i do please tell me?
ADMIN Andrew
Level 3:
Top Expert:
  • Clarion Master 66,977 Answers
  • Posted on Aug 04, 2021
ADMIN Andrew
Clarion Master
Level 3:
Top Expert:
Answers
66977
Questions
Helped
5089643
Points
379913
PIN code is based on the serial number of the unit. The serial number is on a sticker on the back of the unit. Contact Clarion direct. They will tell you the correct code for THAT unit.
Clarion
https://www.clarion.com > ...
SHOPPING TOOLS. Close. SUPPORT. Close. SPECIAL CONTENTS/SOCIALIZE. Close. INFORMATION. Close. ????. PRODUCTS. Multimedia / Navigation · Audio ...
Audio · ‎Multimedia · ‎Speaker / Subwoofer / Amplifier · ‎Support Contacts
Clarion vz400 can't select dvd/cd function
  1. Check the wiring: Make sure the wiring from your DVD/CD player to the head unit is properly connected and secure.
  2. Check the DVD/CD player: Ensure that your DVD/CD player is working properly and that there are no discs stuck inside.
  3. Update the firmware: Your head unit may have a firmware update available that can resolve the issue. Check the Clarion website or contact their customer support for more information on how to update your firmware.
  4. Replace the head unit: If the above steps do not resolve the issue, the head unit may be malfunctioning and may need to be replaced.
If you're not confident in troubleshooting the issue, it's best to seek assistance from a professional installe
I have the manual for the Clarion NX501, but it does not tell HOW to set clock.
Page 51 of the manual, under General Setup Menu, is Clock.
Here is where you set time, AM/PM, or 12/24 hour clock,
2answers
Clarion nx 309 code
Please help me request 4 Digit Password for clarion NX309
Contact Email .. [email protected]
4helpful
2answers
I have a clarion nx501. The micro sd card that has the navigation on it is corrupted. the guys at clarion said that they can't cover this under warranty. please tell me what my options are. i heard...
Please read my post here: http://community.crutchfield.com/forums/p/22187/251957.aspx (pasted below).
I hope you bought your unit at a Clarion dealer....
Hi, (Team Crutchfield - please add this to your knowledg-base.)
I'm on my third NX501 (could have been the fourth if not for working directly with Clarion).
The SD Card corruption causes both loss of Navigation and intermittent Sirius start up (it'll never acquire signal).
Your unit needs to use the exact micro sd card it came with forever (it has a permanent serial number).
You have two choices:
1. Get Crutchfield to replace the unit
2. Call Clarion (I suggest this rather than ripping your dash apart over and over).
Here's what to do. Contact:
Ben Kwan
Customer Service Technical Representative
Clarion Corporation of America
800-347-8667 ext 4342
Direct Line: 310-217-4342
Fax: 310-217-4243
Ben will have you send your microsd and rebuild it for you and return it (likely with the firmware upgrade that addresses this issues on another microsd that can also be found here: http://clarion.com/ca/en/support/navigation_updates/NX501Fupdate/index.html).
While you're at it, update the Bluetooth firmware too: http://www.clarion.com/us/en/support/software/NX501/index.html
Once you get the card returned (THIS IS HUGELY IMPORTANT - EVERYONE WITH A Clarion NX501 SHOULD DO THIS!!!), back it up using Naviextras toolbox (the program clarion uses for map updates). You can get it here: https://clarion.naviextras.com/shop/portal/downloads
Once you follow these steps, barring your micosd physically or logically self destructing, you'll have an NX501 that's nearly problem free and backed up just in case that unfortunate corruption reoccurs.
Of Note: Ensure you insert the microsd card with the contacts facing up and do not force anything.
I'm extremely confident this will make a world of difference for you (and anyone suffering the microsd corruption of the Clarion NX501).
Regards,
Marc (mshmovie)
6helpful
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  7. Attempt to turn on the camera.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
17helpful
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Lost manual
The web. Look up Clarion, them look up model, you might have to pay for it, but I bet you will find it
2answers
Clarion radio wiring diagram
Usually the yellow is for ignition switched-red is permanent +...;)
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
