Re: How do I find model number on a Mitsubishi mr...
It’s on the data plate. Typically on the bottom of a wall hung, behind the filter door on ceiling cassette. Condenser is obviously on condenser outside.
Hi, Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units... Check out this tip that I wrote about that...
hi.right below the model number there is a number that has numbers...model is muy-a24na..this is a 2ton unit...serial is possible the other number...hope this helps you..michael doctor airr appl.repair...843-384-8474...call if need some advice...its free..good luck
Hi my is Paul. it could be a number reasons but i would check to make sure the filters are clean and coil is clean. that thing that looks like a radiator. should be one facing inside the house and anther outside, clean them be careful not to been the fins. Or it could be low on Freon.
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
Visit Mr. Slims website at www.mrslim.com. There you will find a tab for Customer Service. Look in Library to find your model and technical manual. You may have to look at a few to find out what you have for an inside unit, probably it is a PUG.
I am not familiar with a P8 code nor do I understand where you are seeing this But, go to mrslim.com and look under Customer resources, Library and then input your model number. Select Technical & Services. Product Catagory is Mr. Slim Ductless, Sub Catagory is M-series Multi Split, Current models. Remember you have inside units and one outside unit. You will need to look at each model number to find information on both. Usually Mitsubishi's will have two lights that will blink in patterns to indicate what could be wrong. The P8 code is new for this Diamond Dealer!
