20 Most Recent
Mitsubishi MS24WN Air Conditioner Questions & Answers
The compressor seems to run
Is this not cooling??? Or are you just worried about the noise after it shuts down??
Comment back and be more specific about what the problem is....the noise you are hearing after it shuts down is just the refrigerant pressures equalizing after the compressor stops... that is normal. If it is not cooling properly then it is also probably low on refrigerant and has a leak in the piping somewhere...that would need to be fixed and the system recharged...
heatman101
Water drips from ductless unit
You will need to remove the front cover and access the drain pan to clear it. then wipe it clean and follow it up with a bit of hot water and bleach . then allow it to set fora few minutes and follow that up with more Hot water to clear it out . If you are upto it you can put a cloth over the hose and blow a good breath up against the hose. then back away as you might get a bit wet. also check the filter and service it while you at it.. hope this helps .. please let me know jon
Room is warm 86 deg.
The unit has a leak and is low on charge (freon) Find and fix leak, then vacuum and recharge...Leak is probably in flare fittings behind unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Ms24wn/mu24wn--the unit won't stay running.
Hi melder909,
My expertise is on the tv, however I will try to help you because I have a copy of a service manual. Steady flashing of LED light stated there that theres a mis-wiring in the outdoor unit(page 28), check/tighten the wiring as much as possible. The service manual also has a guide flow chart(page 35) fixing this symptoms and it is to long to write here. Do you have an email add, I will send to you a free copy of the service manual.
Jdvillanueva
My outdoor a/c wont come
To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat" Wait for 3 minutes. If no green light shows, problem with indoor PCB.Repair or replace it.
Mitsubishi dxk09z3-s compressor doesnt fire
it would have nothing to do with the gas. how old is it? it could be a few different things. the compressor is gone. the outside board is gone . or the wires from the board to compressor.. how did u try to force it on?
Clean mold from inside wall unit
Cleaning mold from your air conditioner is a simple process. However,
it requires some special supplies. Before you begin cleaning your air
conditioner, gather a vacuum cleaner, a long brush, de-greasing cleaner
and cloths or rags. You will also need a container for waste. Follow
these steps to clean the mold from your conditioner:
Step 1 – Remove the Plate Filter
Using a screwdriver, remove the front plate filter from the air
conditioner system. You may wish to clean the filter with dish or
laundry detergent and water. Simply allow the filter to soak in a small
pan of diluted detergent.
Step 2 – Remove the Plate
Having removed the filter from the front of the plate on the air
conditioner, proceed by removing the grill plate itself. Continue by
removing any other metal coverings, exposing the inside of the central
air conditioner.
Step 3 – Brush and Vacuum the Inside of the Air Conditioner
Using your brush and rags, clean the dust from the inside of the air
conditioner system. Ensure that you remove dirt from every crevice
inside of the system. Be careful not to break the delicate pieces inside
of the air conditioner.
Continue by de-greasing the inside of the air conditioner. Allow the
de-greaser to stand for 15 to 20 minutes before gently washing the inner
pieces with warm water. Ensure that water does not come in contact with
any of the electrical workings.
Step 4 – Vacuum and Drain Excess Water
Before returning the front plate and filter to the air conditioner,
carefully vacuum the inside of the air conditioner system to remove any
remaining dirt and mold spores. Using a cloth or towel, soak up any
excess water that may be left over from the de-greasing portion of the
cleaning procedure.
Step 5 – Reinstall the Plate and Test the System
Carefully ensure that all pieces of the system are not bent or
broken, and then reinstall the front plate. Test your air conditioner to
ensure that it runs smoothly and without loud noises.
In order to best protect the quality of the air in your home, perform
this mold cleaning procedure about once per year. This will not only
serve to improve your overall health, but it will also prolong the life
of your air conditioner considerably.
Take care.
