Hi there, when you turn on the dishwasher, after about a minute it starts beeping (5 beeps a time) constantly. All the program lights are constantly on as well. And it does not start. I have a short video of it. I can send it if the site allows me to. Model G1182SCVi Miele dishwasher
It's not too difficult to troubleshoot washing machine problems. When your washing machine won't spin, there could be a number of possible reasons, but all you have to do is find the right one. A drum that won't revolve and spin is one of the most common washing machine problems and in most instances, you'll be able to find the cause without spending money on a plumber. Once you've found the cause, you should also be able to manage the repair yourself to help keep repair costs down
1) Drive Belt.
2) Pump.
3) Lid Switch .
4) Drive Motor.a
5) Motor Coupler.
6) Clutch.
Note pleasefrom your explanation above it means that you have LID SWITCH PROBLEM
SOLUTION BELLOW
If the lid switch stops working, the washing machine won't spin. In fact, it won't work at all. To access the switch, you might need to remove the top of the machine. With the washing machine plugged in, depress the switch. It should click, but if it doesn't you'll need to replace it.
Thanks
