A
Anonymous Posted on Jun 21, 2021
Clock card machine MARUZEN ATR-501 - Day change
Good day. Would you be able to assist me. I need to change the day setting on our clock card machine, a MARUZEN ATR-501. The date is right but the day is showing Friday, but today is Monday. Thank you.
ADMIN Andrew
Level 3:
Top Expert:
  • The Master 66,977 Answers
  • Posted on Jun 21, 2021
ADMIN Andrew
The Master
Level 3:
Top Expert:
Answers
66977
Questions
Helped
5089480
Points
379911
Question edited into Title - Description, and edited for clarity
Page 7 of the Manual. You have the year set wrong.
https://studylib.net/doc/18894214/maruzen-atr-501-user-manual
How do set the time and date on machine
Press and hold CLOCK until the message window displays C, and the default day is announced.
To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
Press CLOCK. The current hour setting is announced. The correct day setting is saved.
To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
Press CLOCK. The current year setting is announced. The correct minute setting is saved.
To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
To check the clock, press CLOCK.
The above is from page 5 of the manual at
http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
4helpful
Maruzen Time recorder clock
Sorry maybe to late I have the instructions manual if you need it please contact me [email protected]
3helpful
Need to reset time ,day and date
Setting the Clock
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press Play/stop to exit
Setting the Clock at any time.
1 Press and hold Clock until the
2 To change the day setting, hold down memo/repeat
or ANNC/Skip until the
correct day is announced. Then
release the button.
3 Press and release Clock. The current
4 To change the hour setting, hold down memo/repeat
correct hour is announced. Then
release the button.
5 Press and release Clock. The current
6 To change the minutes setting, hold
down memo/repeat or ANNC/skip until the
Then release the button.
7 Press and release C. The new day
and time are announced.
Clock.
NOTE: In the event of a power failure,
see the instructions on the bottom of the
unit to reset the clock.
Record a memo /
Repeat all or part of a message
I hope this helps! here is the URL to the information provided
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
9helpful
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
2helpful
Need to change the date and time
message is received. Press "Play/Stop" to exit
1 Press and hold "Clock" until the
"Memo/Repeat" or "ANNC/SKIP" until the
release the button.
3 Press and release "Clock". The current
"Memo/Repeat"or "ANNC/SKIP" until the
release the button.
5 Press and release "CLOCK". The current
down "Memo/Repeat" or "ANNC/SKIP" until the
7 Press and release "CLOCK". The new day
"Clock".
5helpful
4answers
Need Manual for Memorex voice recorder Model _ MB2054 [email protected]
I have found my instruction manual for Maruzen ATR 501/701 time clock. Email me at [email protected] to arange a copy.
10helpful
3answers
Setting clock
1.Press and hold the (BND) button, then press the (DISP) button to display the clock display.
2.Press and hold the (BND) button, then press the (DISP) button for about 2 seconds (the number will flash).
3.Press the << button to toggle between hour and minute selections. Then turn the ROTARY(volume) knob to increase hour/minutes.
4.Press the (BND) button, then the clock is set!
Kurz
2answers
Maruzen time recorder
i think you need to explain better i.e the type and the model of the stuff you installed.
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
