SOURCE: reset lamp meter on Panasonic PT-43LC14 television
While TV is on, simultaneously press and hold both the TV's Volume Down button and the remote's PP/Play button for 7 seconds.
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
SOURCE: Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Testimonial: "Thank you so much for your help. Worked like a charm!"
SOURCE: My TV model is Panasonic: PT-52LCX15. I have a
Here is a link to replacing the lamp and the instructions for resetting the timer.
I hope that this helps you.
asnowman
http://911phone.net/Panasonic_TY-LA1000_Instruction_Manual%5B2%5D.pdf
I just put in new lamp a few days ago & hour meter needs to be reset
