20 Most Recent Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD TV Questions & Answers
this means your tv has a intermitent problem when the clour ic gets heated up it starts to give you green..so therefore you need to take your tv to a tech to have it repair by replacing the colour ic. good luck.
Panasonic... • Answered on Sep 13, 2011
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Panasonic... • Answered on Oct 16, 2010
You either have a bad Main board or simply a bad touch control button in other word one of your side buttons is defective and it is blocking any other signal to the main board, but usually its a bad main board. In some cases ther is a FIRMWARE update from Panasonic, you may want to call Panasonic or check there website for any type of FIRMWArE UPDATE.
Panasonic TH... • Answered on May 10, 2014
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Panasonic TH... • Answered on Jan 13, 2014
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Panasonic TH... • Answered on Jan 07, 2014
Panasonic TH-42PV7HS 42 in. HDTV-Ready LCD TV Logo
5 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
remote control wasnt working earlier
  • Televison & Video
