You remove the door and then split the inner and outer parts of the door. clean the glass with Easy Off spray, rinse well, polish and put it back together. The videos should help as they all work to a theme.
Yes but it has to be cut perfectly and the ends have to have the same angle cut as the factory one or it wont be able to be properly secured inside the rear covers clamping assembly.
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
To clean between you need to remove one of the pieces of glass...usually the inside is the best....
There are a few screws on the inside of the door theat hold the frame, which holds the inside glass...
remove the frame and carefully remove the inside glass... clean the inside of the outside glass, then clean the inside of the inside glass and then reinstall the froame over the inside glass...
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV. Take off your screen and screen protector and safely set them aside. Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set. It will look like new. You need to do this at least once a year.
CLEANING THE " LENS" MIGHT BE POSSIBLE IF YOU HAVE A LITTLLE SKILL,,UNPLUG THE TV FROM THE WALL OUTLET ,,,,LET ME REPEAT THAT --UNPLUG THE TV FROM THE ELECTRICITY....TAKE THE BACK OFF THE TV---LOOK UP AND YOU WILL SEE 3 PICTURE TUBES POINTING UP,,,ON TOP OF THE TUBES THERE IS A LENS (GLASS)...YOU CAN SPRAY GLASS CLEANER ON RAG OR PAPER TOWELL AND GENTLY RUB OFF ALL THE DUST AND DIRT--USUALLY REALLY BAD IF SMOKERS-- WHEN U GET THRU ,,PUT THE BACK AND REPLUG IN WALL OUTLET--THERE IS ALSO A MIRROR ON PROJECTION TV'S --I RECOMMEND A TECH FOR THAT SERVICING --IF YOU ARE UNCOMFORTABLE ABOUT DOING THIS ----DON'T
THE FRONT SCREENS USUALLY AND RARELY NEED CLEANING...JUST USE A SOFT CLOTH AND RUB TOP TO BOTTOM ON THE OUTSIDE ONLY-GEENTLY TUNICA
