Huffy 26 in. Cranbrook Cruiser Bike Logo
Robert Wills Posted on Mar 18, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I use bearings with a different size bearing balls than stock bearing balls on my rear hub?
ADMIN Eric
Level 3:
Top Expert:
  • Master 39,391 Answers
  • Posted on Mar 18, 2021
ADMIN Eric
Master
Level 3:
Top Expert:
Answers
39391
Questions
0
Helped
805369
Points
588769
Rear bearing/hub nut size or socket size needed
the video i watched said you need a 34mm deep socket.
3answers
How do ball bearings go into a rear tire of a bike
Ball bearings do not go into a bike tire, they go into the wheel hub of a bike. These bearings are in a cage and pressed into the hub of the bike.
Jun 15, 2015 • Motorcycles
1helpful
3answers
2007 ford sport trac rear wheel bearing replacement
Jeff is describing how to replace the front wheel bearings. In the front, the bearing is part of a "hub cartridge". Randy is describing how to change the rear bearings on a truck with a "dead" rear axle. The sort of differential which is one massive cast iron assembly from rim to rim. However, your truck has an IRS [Independent Rear Suspension] design. You need to remove the wheels, brakes & the complete rear knuckle assembly. To remove the bearing from the knuckle requires a hydraulic press and a "knife edge" bearing removal tool. I doubt that you have these tools available. If not, find an auto parts store or auto machine shop with these tools. They can press the old bearing out and install the new one for you. Then you can reassemble the knuckle assembly from that point on. The video linked below should help you.
Ford Explorer Independent Rear Suspension Rear Wheel Bearing and Hub...
With the knuckle off, you can easily replace the ball joints at the same time. Odds are you will ruin the original ball joints getting the knuckle assembly off, anyway.
How to replace front wheel bearing?
old post, but you are first to say front. many others fail to say end of car.
is your car 4wd, as 2wd is different rules. so...??????
I toss coin land on 4WD.
2000 front wheel bearing
got it.
the 2000 year, is important.
this year is the last year, before non untized hubs.
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
my posts is for stock cars. only, and USA spec, cars.
other countries, evolve this in different years.
2000 (never 2001+)
fsm quotes
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Front wheel
    • Brake caliper and rotor
    • Locking hub or hub drive flange, if equipped,(it is)
    • Hub grease cap, if equipped
    • Wheel speed sensor, if equipped (ABS)
    • Wheel bearing lockwasher
    • Wheel bearing locknut (ring) and inner washer
    • Wheel hub and bearing assembly (slide hammer?)
    • Wheel hub oil seal
    • Wheel bearing oil seal
    • Snapring
  3. Press the wheel bearing and race out of the hub.
reverse is same but the lock ring must be set
to 123-180PSI. stop tightening above 123 at first alignment hole in lock ring..
Do you know what bearings a 07 or 08 Capo rear wheel takes. It looks like 10x26x8. Any ideas
Depends on what rear wheel you have. The spec changed on these bikes a few times throughout the the 2 years you mention. Need to know what rear hub you have.
You can take into any bike shop and they can tell you quickly with a visual inspection what bearings it needs. If you have cartridge bearings it will have a number like 6002 on the rubber seal, if they are standard round loose ball bearings than it will be a size like 1/4" for rear.
3helpful
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Remove &replace 95 accord rear wheel bearing
remove this items in this order(rear disc):
-remove rear wheel(the side you are replace)(19mm socket)
-remove brake caliper with cailper bracket(14mm socket)
-remove brake disc
-remove metal cover hub/bearing assembly with flathead screwdriver
-remove 36mm nut behind metal cover.
-pull hub/bearing assembly out.
note:sometime the inner side of bearing stay on knuckle and you have to pry it out pry bar. check old bearing vs new bearing and you'll see the different. Don't reuse any parts of the old bearing.
-install new hub/bearing
1helpful
The bike is circa 1982, ten speed, and the chain stopped rolling as I coasted. I took the rear tire off and removed all the stuff down to the cassett and lots of 1/4 and more 1/16 balls and washers and...
Hi, before the loose bearings are installed you need to insert the shaft through the wheel hub. Then, apply some thick grease to the bearing race, (that's the curved part where the bearings ride). With the grease in place you can "stick" the bearings onto the race one by one. Then, thread the opposing race to that side and hold it in place to repeat the procedure on the other side of the hub. Hope that helps!
1helpful
2002 ford explorer rear wheel bearing removal
Rear Wheel Bearing
REMOVAL AND INSTALLATION
1. Remove the wheel knuckle.
Wheel Knuckle
CAUTION: Do not loosen the axle wheel hub retainer until the wheel and tire are removed from the vehicle. Wheel bearing damage will occur if the wheel bearing is unloaded with the weight of the vehicle applied.
1. Remove the wheel and tire assembly.
NOTE: Have an assistant press the brake pedal to keep the axle from turning.
2. Remove the nut and washer and discard the nut.
3. Remove the parking brake shoes.
CAUTION: Do not damage the boot while separating the toe link from the knuckle.
4. Remove the nut and bolt and separate the toe link from the wheel knuckle and discard the nut.
CAUTION: Do not damage the boot while separating the ball joint from the knuckle.
5. Remove the nut and bolt and separate the upper ball joint from the wheel knuckle and discard the nut.
CAUTION: Do not use a hammer to separate the outboard CV joint from the hub. Damage to the threads and internal CV joint components may result.
6. Using the special tool, press the outboard CV joint until it is loose from the hub.
7. Remove the nut and bolt and the wheel knuckle, hub and bearing as an assembly and discard the nut.
(Return to)
Rear Wheel Bearing
2. Remove the three bolts.
CAUTION: Make sure that the press adapter outside diameter is slightly smaller than the hub outside diameter or damage to the knuckle will result.
3. Using a suitable press, remove the hub from the bearing and discard the hub.
NOTE: The retainer ring is tapered and must be installed flat side down.
4. Remove and Discard the retainer ring.
5. Using a suitable press, remove the bearing from the wheel knuckle and discard the bearing.
CAUTION: The hub and bearing cannot be reused after disassembly.
To install, reverse the removal procedure.
Replacing stock rear axle bearings with "green" brand axle bearings. The green brand wont fit completely down the axle shaft like the stock ones do. The green bearing's inner metal ring wont...
if the bearings are not the same size at originals , then they are not made for that car and are not to be used
If you want better quality bearings by bearings made it Japan, germany or sweden and not china made brands
Top Huffy Cycling Experts
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
