Needing information on removing a heater core from a 2012 Chrysler 200
how to? that it the full steps, out and in,,>????
there is lots of information on this....
not in warranty? huh?
and how could IT be bad so soon?? no way/ ,huh?
why not post the symptoms and not guess. the below HORROR
posted to show 2 days lost work (life)
buy the FSM and read the HVAC chapter. every word
or alldata.com , same deal. look, read and decide,
oops I cant to this.....?
parcial excerpts. to prove case.
quote:
The HVAC housing assembly must be removed from vehicle for service of the heater core.
housing out: 101:
Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in an accidental airbag deployment and possible serious or fatal injury.
WARNING
Refer to the applicable Warnings and Cautions for this system before performing the following operation and . Failure to follow these instructions may result in possible serious or fatal injury.
NOTE
The HVAC housing must be removed from the vehicle and disassembled for service of the heater core, A/C evaporator, air intake housing and the mode-air and blend-air doors.
NOTE
LHD model shown in illustrations. RHD model similar.
Heat Shield - Unified Line 08 JC
Disconnect and isolate the negative battery cable.
Recover the refrigerant from the refrigerant system (Refer to Heating and Air Conditioning/Plumbing - Standard Procedure).
Partially drain the engine cooling system (Refer to Cooling - Standard Procedure).
Remove the top nut (2) that secures the heat shield (3) to the stud (1) located on the dash panel.
NOTE
Two slots are provided at the bottom of the heat shield to aid in heat shield removal. Complete removal of the two bottom heat shield retaining nuts is not required.
Reach behind the engine and remove the two bottom nuts the that secure the heat shield to the studs located on the dash panel and remove the heat shield. Rotate and tilt the heat shield as required.
(capture the FREON as required by USA LAWS, Illegal for DIY person to do. so...)
Unified Liquid and Suction Line to Evaporator 08 JS
Remove the bolt (1) that secures the A/C liquid and suction line assembly (2) to the A/C evaporator (3).
Disconnect the A/C liquid and suction line assembly from the A/C evaporator and remove and discard the dual-plane seals.
Install plugs in, or tape over the opened refrigerant line fittings and the evaporator ports.
Disconnect the heater hoses (4) from the heater core tubes. Install plugs in, or tape over the opened heater core tubes to prevent coolant spillage during housing removal.
HVAC Housing to Dash Panel Nut
NOTE
Make sure to remove the five bolts that secure the HVAC housing to the instrument panel support prior to removing the instrument panel from the vehicle.
Remove the instrument panel (Refer to Body/Instrument Panel/PANEL, Instrument - Removal).
Remove the rear floor ducts (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
Remove the condensation drain tube (Refer to Heating and Air Conditioning/Plumbing/TUBE, Condensation Drain - Removal).
Remove the nut (1) that secures the passenger side of the HVAC housing (2) to the dash panel (3).
NOTE
Use care to ensure that the interior is covered in case of loss of residual fluids from the heater and evaporator cores.
Pull the HVAC housing rearward and remove the HVAC housing assembly from the passenger compartment.
at the least, and for sure , things will break, as you work.
get lost, or not figure out how to put it ALL BACK
Remove the HVAC housing assembly and place it on a workbench (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal).
Remove the left side front floor duct (Refer to Heating and Air Conditioning/Distribution/DUCT, Floor Distribution - Removal).
NOTE
If the foam seal for the flange is deformed or damaged, it must be replaced.
Remove the foam seal (1) from the flange (2) located on the front of the HVAC housing (7).
Remove the screw (8) that secures the flange to the front of the HVAC housing and remove the flange.
Remove the screws (3) that secure the heater core tube retaining brackets (6) to the side of the air distribution housing (4).
On RHD models, remove the air distribution housing from the HVAC housing (Refer to Heating and Air Conditioning/Distribution/HOUSING, HVAC - Removal)
Carefully pull the heater core (5) out of the driver side of the air distribution housing.
end excerpt.
It's better to consult with technicians, I found many HVAC system's parts on
https://www.thefurnaceoutlet.com/furnace... at affordable prices. Furnaces are part of an HVAC system that provides heating. When it comes to installing a furnace in your house.
