I have checked that there is 220vpower and it is wired correctly and have reset the breaker but still nothing. It is going to get cold in the next few days so any help would be appreciated
SOURCE: I have a Carrier 38tra048340
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
SOURCE: Check engine light keeps coming on replaced gas cap already
Your problem is in the evaporative emission system which is designed to prevent the escape of fuel vapors from the fuel system. Leaks in the system, even small ones, can allow fuel vapors to escape into the atmosphere. The light coming on can be caused by one of the following:
1. Defective or loose fuel cap
2. EVAP canister or hose cracked- not connected
3. Purge or vent solenoid defective
4. Vacuum leak at engine
Government regulations require on-board testing to make sure that the evaporative (EVAP) system is functioning properly. The leak detection system tests for EVAP system leaks and blockage. It also performs self-diagnostics. You have tried the easy fix, the gas cap. Finding the leak now will require special equipment and testing procedures, might be better left to a professional.
Please let me know if this information is helpful. Positive feedback is appreciated. Thank You!
SOURCE: I have a honeywell emm-3
check the board for 24 v.a.c. or whatever voltage is used to supply this board,normally its 24v.a.c. from a small transformer,if this transformer burns open the thermostat will not operate
SOURCE: change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
