How to clean Celestron binoculars 15x70 lenses inside?
The objectives' and eyepieces' lenses are full of fungus inside. I made extreme forces to turn the outer ring to remove the objective but I had no success.
NEVER EVER disassemble an eyepiece --- no one can tell you how the lenses go together there are dozens of combinations and some eyepieces have as many as 6-8 glass lenses inside!
Sorry buy another eyepiece and only clean the outside surfaces.
Good afternoon, Without seeing your binoculars it sounds like the white spidery phenomenon growing in your lens is probably fungus. This is usually caused by improper storage or repeated access to water or high humidity. As long as the fungus hasn't eaten into the optic itself it can usually be cleaned off using a mixture of ammonia and water often times even Windex will work. The optics will need to be removed, cleaned and then placed back into the shells and calibrated.typically a repair of this nature will cost between 48 and $89. As long as you don't disturb the actual prisms themselves and you only have to remove the rear eyepiece or the front objective lenses you can usually accomplish this repair without having to recalibrate. If you'd like more information contact me directly with your exact model and make and I would be happy to discuss further repair with you.
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself. Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside. 2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking. 3. Set the rotating eyepiece to the middle setting. 4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one. 5. Pick an object app 10 meters away. 6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus. 7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus. 8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Hope this helps...
Hope this helps...
Hope this helps...
Difficult to answer specifically without knowing the model. But binoculars are designed to view objects in the distance. They all have a limit as to how close they will focus based on the magnification and design. Objective lenses that are far apart such as on a porro prism binocular will not focus very close. The nature of the design of having the objectives further apart than the eyepieces doesn't allow it. When trying to focus too close the image will appear blurred and double. That is the nature of the design. 9 feet or 3 metres is considered quite close to focus a binocular and is usually for a model designed to do this such as a roof prism where the objective lens and the eye lenses are inline. A specialty binocular such as the Pentax Papilo will close focus to 50 centimeters. It has been designed so that the objective (large lenses) lenses converge.
Take into account when focusing that binoculars are also designed to compensate for differences in each eye. One of the eyepieces either right or left will adjust seperately. For binoculars with a center focus ring. First focus using the center ring with one eye covered. The eye that should be covered is the one that doesn't have the adjusting eyepiece. When the image is clear close the eye you have just used and leave the center focus alone. Focusing on the same spot look through the eyepiece that adjusts and turn the eyepiece ring until the image is clear. Now all you have to do is focus using the center ring only as the binoculars are adjusted for each eye.
Some binoculars do not have a center focus and each eye will adjust seperately.
The model of Steiner binoculars is on the plastic plates on the body. On earlier models mainly the green rubber covered military types is is molded at the front of the body near the objective lenses. These were called the Military/Marine and are of a different specification to the current Military/Marine. The original were a military bincocular which has more in common with the current Steiner Military. If you are after the serial number it is located on the front metal disc between the binocular barrels on a porro prism binocular. A porro is where the objective lenses are spaced further apart than the eyepieces. On a roof prism Steiner the serial number is located underneath between the two barrels on the hinge. Roof prisms are binoculars where the objective and the eyepieces are in line. If the serial number is a 10 digit number the 1st and 3rd numbers will give you the year of manufacture.
EG: 9042577777= 1994
If it is five or six digit number then it is the 1st and 2nd numbers
EG: 871245= 1987
Don't "unscrew" the binoculars. there are no user servicable parts inside. the collimnation adj screws are beneath the rubber boot just under where your index fingers rest when looking through the bino's. use a jewelers screwdriver to tease the boot up and stick a small nut or something in. then put the binos on a stable surface and play with the screws a bit while watching the images. you can get them pretty close this way.
