SOURCE: how to fix
hi JPOWER,
my problem in finding a solution to this problem is the fact that Casio doesn't allow anyone who isn't a Casio supplier to download the manual for the CE 3700.
I would firstly suggest that you cycle the power on the machine if you've not tried that already. To do this you need to power down the machine and physically remove it from its power source. Keep it powered down like this for 30s to 1min to allow the machine's memory to clear. Power it back up and try logging in now.
If this doesn't work and you still have the manual for the CE 3700, try looking up some section in it relating to the procedure to restore the machine to its factory settings. With the machine restored to its factory settings you'll be able to log into the machine as if you just bought it, with the down side of losing all the data acquired by the machine before the restore to factory settings was performed.
If this doesn't work either the possibility of physical damage to a electrical component of the register should be considered and could be verified by a electrical technician.
Hope you find this information helpful in solving the problem with your cash register and thanks for using the FixYa service
Kind regards
SOURCE: Getting sam4s out of closed mode
My last day of menstruation was March 16, 2009
and I checked thru pregnancy test; there are two lines although the 2nd line was not as visible than the first, am i pregnant? If yes, when did i concieved, what date? Thank you
SOURCE: I have a samsung e290
I have a samsung E590 and the foto camera doesn't work...can somebody help me with this problem please?
SOURCE: how to void a sale on casio pcr-t275-l cash regester
This is a very simple model, so there are only two ways to remove items in a sale.
If you enter an incorrect item, press ERR CORR to remove the last item.
If you want to remove a previous item, or return an item after a sale, turn the key to RF (refund) mode and key in the item the same as you did in REG mode. This will return it so that it does not affect the daily total.
If anyone needs / looking for a Casio PCR-T275 manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
SOURCE: My cash register is not opening and it says not
You need to sign on an operator, Press 1 then the CLK button.
www.shopstuff.co.uk
just need to know the model number and can give you the reset to factory procedure...couple days plugged in sometimes recharges those nicads enough to recover.
