In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
SOURCE: Sharp Aquous will not turn on.
I would check the System Cable that is linking the box to the TV. Then, press the small button called CLEAR in the front of the box. The button should be behind the flip cover on the front right below the PC input ports.
Let me know if this solution works.
SOURCE: Sharp Aquos LC-32D41U takes a long time to warm up
Hi, it could be a dry solder joint on the circuit board
SOURCE: no sound on sharp tv flat screen model LC when turning on again
we fixed the problem, no further assistance required
Thanks
