20 Most Recent Sharp LC 37D62U 37 in. LCD HDTV Questions & Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sharp LC 37D62U... | Answered on Aug 26, 2014
You have a flew tab issue ( where the circuitry attaches to the screen) which is located under the screens top frame section. Or there could be a blown resistor or didode on the small board the flex tab attaches to also underneath the top frame section of the screen assembly
Sharp LC 37D62U... | Answered on Dec 16, 2012
You can download it free from sharp website.
Sharp LC 37D62U... | Answered on Mar 21, 2011
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Sharp LC 37D62U... | Answered on Sep 12, 2010
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Sharp LC 37D62U... | Answered on Jan 05, 2010
On some cable boxes they have their own volume control. Raise the volume on the box if you can. if the volume on the tv is up all the way it should be loud. It should not be the tv if you have volume already coming out. try hooking up a dvd player or some other device and see if you have the same result
Sharp LC 37D62U... | Answered on Dec 08, 2008
The control board is defective. Is in warranty so call Sharp to have it fixed.
Sharp LC 37D62U... | Answered on Dec 30, 2007
Menu on remote and make sure you have it on wide screen or 16 to 9
Sharp LC... | Answered on Jan 17, 2019
Hello
If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them.
For any help or support just visit us: www Roku Com Link
Sharp LC... | Answered on May 26, 2018
Sharp LC 37D62U 37 in. LCD HDTV Logo
18 questions posted
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
get manual sharp equos
  • Televison & Video
