SOURCE: Print the date on the image/photo
It is not possible to embed the date/time stamp as part of the image itself with the XT. The date/time information is stored as part of the exif information stored in the image at the time of shooting.
However, you do have a couple options for printing images with the date/time stamped onto the image:
If you use the direct print capabilities of the camera when connected to a compatible printer (PictBridge, CP, or DirectPrint are all supported), you are able to enable an option that will print the image with the date/stamp printed on the image. There are also software packages that you can use that will do the same when printing from the computer.
And finally, it is possible, with some photo finishers, to request that they imprint the shooting date/time on the image. This will vary from photo finisher to photo finisher, and the will be some who can't, or won't, do this.
SOURCE: Date and time stamp
I wish to have this issue solved too!
It is very useful to have timestamp optional as in most other cameras...
E.Sarris
SOURCE: I cant seem to change
open the menu, and navigate to the middle icon, then down to "simple mode". Turn off "simple mode" to show all menu options
SOURCE: I inserted a 4GB SDHC
I assume that the camera is not compatible with SDHC cards and will only work with normal SD (upto 2GB) cards.
SOURCE: need manual for wildgame innovations
http://www.wildgameinnovations.com/pdf/s1.3%20Camera%20Booklet2010.pdf
My TX12i8D-8 has exactly the same symptoms. Formatting SD card and trying different SD cards and using fresh batts did not help. It is about 2 years old so probably it's just done.
