Kernal panic alert screen frozen. am a novice tried power key still will not respond ? was erasing files when all seems lost!!!! help!!
Well, if you erase the wrong files, you'll sure get a kernel panic.
To power down your PowerBook when there is a kernel panic on the screen (or any frozen state) you have to hold the power button for 10-15 seconds until the Mac shuts off. Then you can restart it.
If you deleted too many of the wrong files, it may not restart to your satisfaction. :-(
01-11-2010 10:59 AM
If the handset is locked, frozen, or unresponsive, you can perform a master reset it using the hardware keys instead of the menu. A master reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). To perform a master reset using hardware keys, follow these steps:
1. If the device is responding at all, back up your data before proceeding.
Note: The device must be turned on to synchronize or transfer files.
2. Turn off the device.
Note: If the device is unresponsive and does not turn off, remove and then reinsert the battery.
3. Press and hold the Home key and the Power key for at least 25 seconds, even if the Startup screen appears.
4. Release the keys when you see a black screen with a warning sign.
5. Press the Home key and the Power key again.
6. When the Android system recovery utility appears, use the trackball to scroll to and select Wipe data/factory reset.
7. Once the device finished the data wipe, select reboot system now.
