Tablets & eReaders Logo
m
mark lashorn Posted on Sep 18, 2019
I need to reset tablet factory setting I just got it and it won't let me on
Brian Acker
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 18, 2019
Brian Acker
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
1686
Points
25
Yes a reset might fix your issue with not being able to log into your tablet.
3 Related Answers
Anonymous
  • Posted on May 06, 2012
SOURCE: how to factory reset toshiba thrive tablet. can't get past log on due to previous owners lock, unlock password
taking the battery out will do it
TechyDrood
Justin
  • 2072 Answers
  • Posted on Nov 27, 2012
SOURCE: want to reset to factory settings
This option will typically be under
Settings > Storage > Factory Reset
Deneenie
DLewis
  • 73 Answers
  • Posted on Dec 22, 2012
SOURCE: reset kurio 7 tablet to factory settings
press and hold VOL+ and Power button simultaneiously.
http://www.kurioworld.com/us/pdf/Kurio_Manual_US.pdf
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
3helpful
2answers
I'm trying to do a factory reset
Terri, The links can show how to factory rest on a tablet.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Factory Reset Your Android Phone or Tablet When It Wont Boot
Android tablet not working Factory reset using keys
http://www.androidtablets.net/threads/how-do-i-factory-reset-my-tablet.62022
How do i reset my digital2
To factory reset your tablet - Open system "Settings", then "Backup & Reset", then "Factory data reset". Once reset, all settings will be restored to factory default settings and user will be required to do the initial setting.
How to reset factory settings
On your tablet, tap on Settings > Personal > Security. The reset to factory settings option will be near the bottom.
Reference: Lenovo Yoga Tablet 10 User Guide.
https://www.cellphones.ca/upload/manuals/lenovo-yoga-tablet-10-manual.pdf
Hope this helps!
2answers
My tablet keeps on going back to the loading screen and repeats that
You will need to reset the machine to factory settings by holding in the "Reset" button with the power on. Then just wait until it reboots. If this doesn't work you may need to get the Operating System re-installed.
Want to reset to factory settings
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
