Cell Phones Logo
Michael Chukwuemeka Posted on Sep 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change my nokia 1280 from arabic to english
Terry
Level 3:
  • Nokia Master 11,377 Answers
  • Posted on Sep 16, 2019
Terry
Nokia Master
Level 3:
Answers
11377
Questions
Helped
4626864
Points
152765
Possible procedure to follow shown at the internet link below:
http://kb.brightroam.com/KnowledgebaseArticle50001.aspx
5 Related Answers
Anonymous
  • Posted on May 12, 2009
SOURCE: How do i change my language from arabic to english
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
Anonymous
  • Posted on Jun 27, 2009
SOURCE: i mate 6150 how to change the language arabic to English
hello
today i am going to show you how to change language arbic to english. First you go on
control panel. And then you see there regional languge you can see there lot of languge you.
Now wich language do you want you then you select that's it .
Anonymous
  • 263 Answers
  • Posted on Jul 29, 2009
SOURCE: change windows xp from arabic to english
reinstall service pack 3 with language pack from microsoft.Make sure you back up your registry first.
For xample
If you have XP SP2 in ENG and want to have it iArabic, you will have toDownload SP3 in Arabic (http://www.Microsoft.Com/downloads/details.Aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en change language to desired one then download), change some registry Keys (go to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language Registry Key, and then change the value date for “Default” and“InstallLanguage” Registry value from 0001to 4001) reboot and you'll be able toInstall SP3 in Italian.
  • 0001 = "ar;Arabic"
  • 0401 = "ar-sa;Arabic (Saudi Arabia)"
  • 0801 = "ar-iq;Arabic (Iraq)"
  • 0C01 = "ar-eg;Arabic (Egypt)"
  • 1001 = "ar-ly;Arabic (Libya)"
  • 1401 = "ar-dz;Arabic (Algeria)"
  • 1801 = "ar-ma;Arabic (Morocco)"
  • 1C01 = "ar-tn;Arabic (Tunisia)"
  • 2001 = "ar-om;Arabic (Oman)"
  • 2401 = "ar-ye;Arabic (Yemen)"
  • 2801 = "ar-sy;Arabic (Syria)"
  • 2C01 = "ar-jo;Arabic (Jordan)"
  • 3001 = "ar-lb;Arabic (Lebanon)"
  • 3401 = "ar-kw;Arabic (Kuwait)"
  • 3801 = "ar-ae;Arabic (you.A.E.)"
  • 3C01 = "ar-bh;Arabic (Bahrain)"
  • 4001 = "ar-qa;Arabic (Qatar)"
If noProblems occur, you will have the whole system language changed.
Anonymous
  • Posted on Apr 14, 2011
SOURCE: need to change from arabic
change to english language nokia x3 02 from arabic
Anonymous
  • 25 Answers
  • Posted on Feb 17, 2012
SOURCE: how to change language on nokia e52 from arabic to english
Hi there
I have found the userguide for the device on :http://nds1.nokia.com/phones/files/guides/Nokia_E52-1_UG_en.pdf
There on page 161 , it stats :
Language settingsSelect Menu > Ctrl. panel > Settings and General > Personalisation > Language
due to be at arabic language may nedd to check the icons on userguide.
I hope this information can help you.Best regards
I have somehow changed the phone mode to Arabic and want to change it back to English but dont read or understand Arabic how can I change the mode back to English
Hi John, I would either ring or better still take the phone to a Nokia store as I'm sure somebody there would know what to do.....
1helpful
7helpful
Need to change from arabic to english nokia x3-02
6helpful
How do i change from arabic to english on nokia n79
Follow the steps below.
Go to Menu---->Settings---->phone---> Phone language.
You can change your language from Arabic to Engilsh.
Thanx
1helpful
2answers
Hello i use nokia 5130 xpress music by mistake i
follow the menu numbers in upper right part in english, upper left in arabic. to go to language settings to english go to Settings#7, then Phone#11, then laguage setting #1, then Phone Laguage#1, then choose the language pack #1 is usually automatic that why maybe it chose arabic depending on your region. English is usually #2.
19helpful
3answers
I want to change language arabic to english from my e66 mobile
I did a google transliteration for LANGUAGE and got the result. Look for the corresponding word in the settings icon and change language to ENGLISH.
Or if you can follow the icons it will be in this order;
MENU>TOOLS>SETTINGS>GENERAL>PERSONALISATION>LANGUAGE(FIFTH AMONG THE DROP DOWN MENU)..Hope this helps...
3answers
Change arabic phone settings to english
you can change the default language to English , if you can clarify which phone you are using I can help you change the language
21helpful
3answers
How to change language from arabic to english
I cannot change settings of my i-mate jama 201 since it's in arabic. how can i change it to english?
Arabic fonts not showing on Nokia E61 English/Arabic phone
Have u tried the option of setting ur phone to unicode accept characters...refer user guide
(This will work, only if ur arabic lang font is based on unicode)
anyway, give it a try
Mar 03, 2008 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
