I did a google transliteration for LANGUAGE and got the result. Look for the corresponding word in the settings icon and change language to ENGLISH.
Or if you can follow the icons it will be in this order;
MENU>TOOLS>SETTINGS>GENERAL>PERSONALISATION>LANGUAGE(FIFTH AMONG THE DROP DOWN MENU)..Hope this helps...
I want to change my phone language arabic to english.
Go to Settings then Phone Settings then Language..
SOURCE: help me change language of samsung SHG i300 Widows mobile
i have your solution but i need your help: i need ur arabic software cuz my i300 doesn't read arabic sms
if u can send it i'll be greatfull
your solutionis is to format your mobile (dont worry your files will be saved): tunr off your mobile, hold on ( 0 ) and press the start bouton(red bouton) it will takes 3 to 5 min . now ur mobile is like new with english language!!!!!!! enjoy
my mail is [email protected] if u can help me!! thx
SOURCE: How do i change my language from arabic to english
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
SOURCE: i want to change language
change the language in nokia E66
1st Go to Tools ( your cell 5th option )
2nd Go to setting ( your cell 5th option )
3rd Go To general ( 1st option)
4th go to renationalisation (1at option)
5th go to language (5th option)
6th go to phone language (1st option)
than open your other language option
100% tested by me
SOURCE: its in arab language iwant to chang to english
Tap on Start > Settings (it is represented by a gray gear in front of an yellow folder. It should be the second item, from the bottom to the top, the closest one to the question mark, which stands for Help). Tap on the second tab (standing for 'System') and search for an icon representing the Earth (standing for 'Regional Settings'). Tap over it and choose the language that better suits your needs, in the dropdown menu. Tap OK to save and quit.
This procedure won't change the entire ROM to the language you want, of course, but will allow you to better understand what is going on with your device.
Hope you are able to sort your problems out.
Regards,
Carlos
