The refrigerator flashes '15' E on the display . The freezer is freezing, i am not sure about the other side, i have not notice anything wrong. Defy DFF417 model
SOURCE: Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
SOURCE: refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
SOURCE: DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
