Yes all of them. its a special type call your local equipment rental facilty, its not readily avail normally
There are certain pressure washer that do require oil. It depends on your make and model of he machine.Usually they require, when it is a gas powered unit and then if its a 2 cycle gas engine they
take a gas/oil mix in the tank and do not require oil in a crankcase.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Type of oil for pressure washer pump.
any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
SOURCE: oil used for Cat Pump on pressure washer?
It will be a 30 wt non detergent oil probably. You could contact a Rental store in your area they will have what you need. Hope this helps. 2rns4u <*{{{>(
SOURCE: How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
