I bought a new deck and im trying to instal it, but usually the +,- wires i can tell apart those look identical. I need a diagram or something like that.
Red is power to from ignition to cd deck
Yellow is direct power from battery to cd deck to hold the memory.
Black is ground
Blue is only needed if you are hooking up an amplifier.
I always suggest buying a wire harness quick connect system for $5, then you won't have to cut origional car wiring. If by chance you are taking the original wire route, then go to installer.com to find which wires on the car are for what.
Testimonial: "GOOD STUFF!!!"
1995 Toyota Celica Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): Whi
Testimonial: "it helped out."
