Expert
- Posted on Aug 11, 2009
Re: Poulan Chainsaw Gas line and filter from tank is...
Did you check the fuel pump...is it pumping fuel? did u check also the ignition system if it has a spark? check the spark plug it might be flooded with fuel. hope this helps..
Yes I have spark. I can put gas in the combustion chamber and it will start & run a short time. The pump is obviously not pumping fuel into the combustion chamber however why it isn't is the BIG QUESTION!!!! Replaced with a new carb and same thing thus it is not the fuel pump.
Lee
