I was just testing my camera after i changed the batteries. Everything works fine until i changed the shutter into automatic. Suddenly the lever stuck and i cant advance it. Any help?
SOURCE: Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
SOURCE: shutter remains open
it is out of batteries.if you notice the meter doesnt work when the lever is put in the on position.M90 was designed so you can still shoot in case you run out of batteries.
SOURCE: 35mm Film Camera Ricoh XR-2
You can replace it with the available lever.Most of the cameras lever can suit
