20 Most Recent
Ricoh KR-10 SE 35mm SLR CAMERA w 50mm f/2 P LENS & MOTOR DRIVE *EX* $79 Questions & Answers
Why can't I see through the viewfinder?
Are you sure that is the model? If it is, those film type cameras have an actual mirror in them that flips up when the shutter button is pressed, then it comes back down. If this is the case, the mirror is sticking in the up position.
Ricoh KR-10 SE...
Answered
on Feb 03, 2016
My Ricoh KR-5 won't keep the film door closed. How
The film doors in most 35mm SLR's is spring loaded with a release from the rewind knob. Chances are your spring has lost tension, slipped out of place, or the teeth that grab the door have been damaged. You can always use the handyman's secret weapon (duct tape) to fix the problem, but if you're looking for a more permanent and less gooey and unattractive solution you're going to need to find a shop.
If there aren't any locally, you can find some online, or google KEH Camera if you're not sure who online is reputable. It'll run you $35 for a repair estimate which is waived if you decide to have the work done. Keep in mind some parts, for some cameras, are hard or impossible to come by so your model may or may not be able to be repaired, or may be priced outside of what you're willing to pay to have repaired.
Photography
Answered
on Sep 09, 2011
I have an older KR-5
Unfortunately, you won't find new spare parts as the model is so long out of production and the manufacturer ceased to exist many years ago. The difficulty is compounded by the fact that there is so little money in servicing and repairing 35mm SLR cameras that most repairers have ceased trading. If you do strike lucky, then unless the part is very cheap and you have the skills to fit it yourself it makes no economic sense at all as the body in excellent cosmetic and functional condition is only worth £5-£10 in the UK (where I am) and probably less in the USA.
The only source will be from a used donor model, but as there are plenty of KR-5's, KR-10's and similar Pentax K-mount bodies lying unused these days why bother paying for one? Almost every 35mm SLR and lens I've acquired in the last six years has been totally free via my local FreeCycle and Freegle groups, and most have been fully functional or just needing new batteries and light seals.
If you're really determined to save your camera then you maybe able to fabricate the spring yourself, but it's been so long since I took a KR series model apart that I don't recall the design so it may be an impractical suggestion.
Good luck, and sorry that this is not the answer you were hoping for.
Photography
Answered
on Mar 03, 2011
