1. Check your connections. If you suspect your AirPods case isn't charging, the most likely culprit is something preventing the charging connection, and that's most likely because the charging cable isn't inserted completely if you're using wired charging, the cable is damaged, or because the case isn't making good contact with the wireless charging base if you're charging wirelessly.
2. Take the cable out and reseat it to see if your charging light comes on. If not, try using a different cable. Or, if you're charging wirelessly, try using a wired charging connection.
3. Charge your AirPods case. If your AirPods case will charge, make sure it is completely charged. If it is completely charged, the charging light will turn green.
If your wireless earbuds are broken or damaged, see this post for some recommendations: Best TWS Wireless Earbuds 2021
Make sure the top lid is closed tightly.
SOURCE: How long do Airpod batteries last? How do you charge them?
At least 2 years. Any number of ways is available to charge them, I suggest wireless chargers.
