I’d recommend checking out Ace Hardware. They are well known for carrying speciality hardware. As far as the type of screws required, it looks like that depends on the way you want to mount the TV onto the wall. Google AN-52AG4, the model of the wall mount recommend by Sharp. You should find a link to files.sharpusa.com that will take you to the wall-mounted manual which tells you the type of screws you’ll need. If you aren’t using the recommended wall mount, refer to the installation instructions of the wall mount you are using to find out the size of the screws you need.
SOURCE: I just moved and I can't find the stand screws
call this store and they will be sure u get the proper set of screws
http://promotions.partstore.com/Brand-Landing-Pages/Sharp/Sharp-A.html?s=google&gclid=CPWG3YmvpJsCFRd75Qodp0w9Bg
SOURCE: Missing LCD Stand Screws for Sharp Aquous 46" LC-46D62U
am not sure on size service manual doesnt say but there 2 1/2 long.
SOURCE: I have a Sharp LC-32SB24U.
Just make an educated guess judging by the size of the bolts you do have, whether they are too big or too small, or you could measure with a measuring tape by measuring the head of the bolt. Then take those measurements to your local hardware or other store and either you will be able to find one you feel confident about size wize or you can find someone to help you. As far as specific bolts go there really isnt a difference, as long as you get a decent size, if its a little too big it will be ok as the threads will just cut their way in regardless.
Hope this helped.
SOURCE: Lost my Vizio VO42L base stand screws (8). Can I
The exact size for this and almost all visio TVs are:
M4 x 35mm at .70 pitch
Hope this Helps the next guy/gal that looses their screws...
