Contact the manufacturer to see if they will warranty the product or if they may send you a new latching mechanism. They will probably want you to send them a picture with your phone to document the problem. Here is the link to their website. https://www.coscokids.com/
SOURCE: Broken stroller's tray post
I just had the same thing happen to me! I sure do hope there's a way to fix it- I am currently trying Krazy glue- am hopeful! Any suggestions would be great for a more permanent fix! Thanks!
SOURCE: cosco umbrella stroller
it might be easyer to buy a new one, Wal-mart and Zellers sell them for under 20$
SOURCE: closing/ folding stroller
Sometimes you need to pull a bit further to unlatch the 2 pieces at the bottom of the stroller that hold it together.
SOURCE: cosco juvenile stroller -- how do i change the
I have the same stroller. Look behind the seat back, where you should find a ring and a squeeze clip similar to those used to close bags of chips. Hold the ring, squeeze the clip, and push the seat back towards the front of the stroller.
SOURCE: can not close rear/cargo door, after depresing
Try spraying some lubricant into the latch and handle assembly and pull it back and forth to work it in.. You may want to remove the rear trim to get better access to the internals of the latch cable....
Testimonial: "Did it and now works like new! Thanks a lot!"
Inspect the stroller's wheels and handle to identify the type of brake mechanism it has. If the device is equipped with wheel-mounted brake levers and swivel locks, use the toe of your shoe to activate these mechanisms. If your stroller is equipped with a handle-mounted brake lever, push down on the lever to engage the brakes. Some models also come equipped with a secondary-locking mechanism located on one of the rear crossbars; use the toe of your shoe to activate this feature. Lift the handle or press the tab securing the backrest in place, located on the upper edge of the backrest or on the crossbars securing the rear of the backrest to the frame. Grip the edges of the footrest, then lower the component by pushing it into the desired position. Pull back the stroller's canopy. Grip the stroller's handle and lift the device upward; if the stroller comes equipped with a safety button, press the button as you lift. Use the toe of your shoe to push on the stroller's hinges until the frame begins to fold. Pull the halves of the stroller's frame together until you have completely folded the device; if the stroller comes equipped with a locking latch, engage the latch to keep the halves from sliding apart.
Step 2
Step 3
Step 4
Audi Parts
