KitchenAid Pro Line Coffeemaker Coffee Maker Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid Proline program light doesn't stay on & it won't auto start brewing
Anonymous
Level 2:
  • Expert 145 Answers
  • Posted on Aug 08, 2009
Anonymous
Expert
Level 2:
Answers
145
Questions
0
Helped
154319
Points
404
Pro Line appliances have an extended 2-Year hassle free warranty on them. If you are experiencing any problems with a Pro Line coffee maker, I would suggest calling Kitchenaid Customer Service.Their toll-free telephone number is:
1.800.541.6390.
Breville you brew auto start not working
There is an error in the manual. Following the directions will, as you discovered, start brewing immediately.
To complete the auto-start programming, in step 8 of "Programming Auto-Start" you should NOT "press the PROGRAM button."
Instead, as soon as you have set the desired minute of the Start Time (step 7 in the manual), press the START / CANCEL button.
The LCD screen will then dim and display 'PROGRAM ON' to indicate that the Auto-Start feature has been successfully turned on.
Hope this helps.
- Owen.
1helpful
How do i program a black & decker model cm1050w to start coffee breding at a certain time?
I have one. It's easy. Push the program button. The little green light in the lower left corner will flash. The only tricky part is that you only have about 3 seconds to begin setting your time. After that the light stops flashing and you will be changing the regular time. While you are pushing the Hour or Minute buttons you have all the time you need to set your brew time, but once you stop you're back to the 3 second timer. Remember, if the light in the upper left side is on, the time is PM. To turn the timer on, push the Auto button and the little light in the lower left will come on and stay on. To turn it off, just push the Auto button again. Another caution, there is no "safety" for the Hour and Minute buttons. If you push either of those buttons while the lower left light is flashing you are changing the brew start time. If it is not flashing you are changing the real time. In other words, if you push either of those buttons at any time, you are always changing something. Happy brewing.
2helpful
2answers
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
PROLINE FD28E DEEP FAT FRYER REPLAYSMENT BASKET
Go online to the Kitchenaid company, & check out site for replacement parts. Good luck.
2helpful
How do you set the clock and program to brew at a specific time?
To program the Auto On
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
3helpful
2answers
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
3answers
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Top KitchenAid Coffee Makers & Espresso Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
