20 Most Recent
KitchenAid KCM511 Coffee Maker Questions & Answers
My coffer pot gurgles and it takes 20 min to make a pot of coffee!
I had the same problem with a regular coffee pot. The problem was a large piece of coffee ground that was lodged in the water tube check-valve going to the element. This prevented water from getting to the element quickly enough, and what water did get there mostly turned to steam. We had to remove/replace the tube.
Error #2
Our kirchenaid coffee maker says error 2...what do we do
Kitchenaid coffee pot won't brew coffee reads err2
An ERR 2 may be cleared by a simple reset of the coffee maker. This
means unplugging the unit and plugging it back in. When powered back
on, select a brew function to see if the error reappears.
If it does reappear, ERR 2 indicates an internal error with the computer of the
warming plate. This may be covered under Kitchenaid's 1 Year Hassle
Free Warranty. I would advise you to call Kitchenaid Customer Service
to see what options are available to you. Repair is not recommended, as
it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Error 2-Unit will not heat or brew. Stopped in
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
