My tractor has a PTO hydraulic pump for the bucket. Can the hydraulic outlet on the back of the tractor be used for the bucket?
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
SOURCE: Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
SOURCE: Ford TRactor 1710 hydraulic problem
raise front loader....loosen hyd. line a little lower loader till all air is released and only fluid is coming out and retighten.....its like bleedig brakes on a car
SOURCE: where will i find the hydraulic filter on my
The filter and suction strainer should be behind the hitch or "lift" cover. There will be a paper filter element normally with a suction screen under it. Be sure to pull the suction screen and clean the area surrounding it. You may be able to call your the Ford/New holland dealer for your area and get a little more precise information also. As I recall these are common sump with the transmission, but I could be mistaken on that. Best regards, Marvin
Testimonial: "thanks so much all the manuals i had found didn't help "
SOURCE: 2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
