Question about Ford 8n,9n,2n, Tractor Starter With Drive
Install distributor points on ford 9n process needed
I have looked everywhere for a free download exploded view of the distributor of the Ford 9n tractor.
  • 1 more comment
  • Anonymous Apr 08, 2009
    Thank you, Been there. I need to take it apart, just need a picture to make sure I put it back together right.
    Front mount. with two plug wires on each side. thank you
    The Pic ould help so very much. What a blessing.
    e-mail [email protected]
Dennis Yachimec
    Sniper:
  • 79 Answers
  • Dennis Yachimec Apr 08, 2009
    is this dist. front mount or side mount ??
    Hi
    Procedure to replace points - first remove distributor cap mark plug wires so you can put them back in same order. Turn engine over and have rotor pointing start up for reinstalling. Remove distributor from engine and replace necessary parts, adjust points to .016 and reinstall distributor with rotor pointing start up. Have a neighbor who has the manual for the 9N tractor. Can take a picture and email it to you required. I will need your email address for this. Please let me know if this helps you out.
    Dennis
How do l get a distributor diagram for a 1988 Ford ranger 2.3
Are you wanting the wiring diagram or distributor exploded view, all the above?
Autozone.com
Has free auto repair info and wiring diagrams.
How do you take a starter off ?
Type you tube on Goggle. Then type 9n tractor- starter removal
View the viduo
Ford 9n converted to 12 volt alt still 6 volts at dis. runs rough till i jump 12 volts to coil and then it runs good. Will this damage coil and points?
If you are doing 6 Volts at the distributor you must either have Resistor wiring or a separate resistor in the system. They make both 6Volt and identical 12Volt coils for your unit.
You will eventually burn up a 6Volt coil if you use 12Volts on it. There is an aftermarket company which has Antique supplies. Carpenter(Maybe John) has supplies for Tractors, cars and trucks that are earlier models.
Do a Web search using his name and marry it to Tractor parts, etc.
3helpful
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
Top Ford Garden Experts
Fahr Quad
NOEL
NOEL
Are you a Ford Garden Expert? Answer questions, earn points and help others
