Computers & Internet Logo
Posted on Aug 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Internet connection with Sony VAIO VGN-FS115B
I have a Sony VAIO VGN-FS115B using an Intel(R)PPRO/wireless 2200BG network connection driver.
My problem is that I cannot connect to the internet using wireless although it has been working OK up until recently.
The 'wireless network' shows that I am 'connected' and with strong signal strength.
Device manager tells me that my driver (see above) is 'working correctly' and that there 'nothing better' when I requested an update.
I can get onto the internet using an ethernet cable connection.
Another laptop is able to use the wireless internet using the same modem/router as mine so I think I can discount that as a possible cause of the problem.
I would appreciate your help in sorting this out please
Kind regards
Len, in Melbourne
Anonymous
Level 2:
  • Expert 135 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
135
Questions
0
Helped
69100
Points
264
Try reinstalling the Wireless LAN driver
I want to get all my sony vaio vgn-s590b driver program because i cant get wifi signal n lan for the internet'
Unfortunately, the Wireless card in the VAIO model VGN-S580B does not support n standard. The integrated Intel PRO/Wireless 2200BG Network Connection Driver supports IEEE 802.11b and IEEE 802.11g standards. It is require to use an external Wireless card to use the n standard.
However, here is the link to download all the drivers for your computer model:
http://esupport.sony.com/CA/perl/swu-list.pl?mdl=VGNS580B&LOC=3
Thanks
I have a problem wid my network driver in vgn-cr220e, pls tell which driver will be install
you can downloading it here depending on which version of the Windows you are using. the wired network driver is Realtek® 8169 PCI, 8168 and 8101E PCIe Ethernet Network Card Driver , the wireless network driver is Intel Wireless
Internal Wireless for Sony Vaio VGN-B100B?
A simple solution is a USB Wireless Card... Linksys is my Fav...
If you have a wireless card in there you would see a indicator light on the top of the laptop...kinda like the HD light or power light. If it is on... it will be lit.
My Sony SONY VAIO NR Series VGN-NR430E/S NoteBook is saying there are no available networks when I go to connect to the internet. This never happened before and all the other computers are connecting to...
Hi sheppardr,
You need to Update the Wireless LAN Driver in the Computer to fix this issue. You can download and install the Update from the below link to fix the issue with the Wireless Network.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR430E&upd_id=4751&os_id=28
Please download the file to a folder in the Computer. Then, please open the folder where the files is downloaded and double click on it to begin the installation. Please follow the onscreen instructions to complete the installation. After installing the Update, please restart the Computer for the settings to take the effect. This should fixit.
If the issue persist, you can try updating the Driver using the "Intel Driver Update Utility".
To run the Intel Driver Update Utility, please open the below link in a new Web browser window.
http://www.intel.com/support/wireless/detect.htm
Then, click the "Check you System for the latest Updates" button, you may need to install a add-in to begin the process. Please click the Yes button to install the Software. Then, the Update Utility will start searching for the Updates for the Device detected in your Computer. This will show-up all the Updates for the Computer. Please download and install the Update for the Computer. Restart the Computer when Prompted.
This should fix the issue with the Wireless Networks.
Best of the Luck!
Thanks for using Fixya.
1helpful
Sony Vaio XP Downgradation Wireless problem
Same Problem I am facing too. I am also having SONY VAIO VGN-CS21GN
Wireless network on sony vaio
Sir,
check the links below and go through the sites......u have a solution
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
1helpful
3answers
Drivers forsony vaio laptop,Model No. VGN-FS15GP
Use this drivers >>
For Sony Vaio VGN-FS115B - I use it for my VGN-FS15GP and it works fine
For Fn - hotkeys problem use:
1) Driver Control
2) and utilities package
Paul
Problems with Intel Pro/Wireless 2200BG Network Connection - Constantly connects and disconnects me from web?
Try using the Sony with an external wi fi adapter. The internal one could be bogus. Before adding new one, go into Device Manager and Disable the existing one in your Sony. Then add the new one with its software.
10helpful
5answers
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
Grand Canyon Tech
Grand Canyon Tech
