SOURCE: need to activate my new Locman 1974 self winding watch
this website may be helpful to solve your problem
http://www.finewatchmaking.com/
SOURCE: problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
SOURCE: How do I open a medana pocket watch?
First -let's check out what type of watch you have. If you push the crown in and it turns freely back and forth with no resistance at all - this is battery driven watch.
If you do the same and feel and hear some clicking and resistance- this is mechanical (spring driven) watch.
Next - the case: Usually all pocket watches have snap-on casebacks. Take an eyeglass and examine the case. Even if you think there is no any grooves or gaps- try to pry it using watchmakers caseback opener (about $5 on ebay).
In case if there are no chance to open caseback - that means you have one of the cases assemblad watch glass fitted last and that means you have to take glass out first and then only to get to the movement.
As you will not be able to get the glass out without braking it, the only solution will be to visit your nearest watchmakers shop and ask for help.
Rate, please.
SOURCE: baume & mercier hampton city watch
Does the dial have "Automatic" wtitten on it". If it does then it's a mechanical movement. If it has "Quartz" then it requires a battery. If the watch isn't running perhaps it just needs a battery. This may also explain why the pushers aren't working. If it's mechanical the watch needs to be wound before the pushers will work. What are the markings on the subdial.
SOURCE: Watch is not working. Does it have a battery or
I examined all the watches on their web site and they are all quartz movements, so it looks like your is a battery operated (I couldn't find 0292 but I did find a 2092 - which has a quartz movement).
