Watches Logo
Posted on Aug 13, 2018
My Wittenaur Watch Band Clasp Broke! Need Repair Info! # On Back Of Watch Is C9871135
3answers
HOW DO YOU REMOVE A GUCCI WATCH FROM YOUR WRIST?
This is so called ''snap-on'' butterfly clasp. There is no release mechanism and simple pull is needed to open it. Use your strength on do not worry - it won't brake.
5answers
Kennith cole reaction watch
try to change your settings of your clock by getting it full circle to get back to real time and see what happens. if still problem persist then you might send it to repair service or it should have warranty service for an expensive watch. hope that helps!
CHARCOIS
Oct 01, 2008 • Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 • Watches
1helpful
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
2answers
Broken watch band TH 6000 WH1151
This has happened twice to me. First time they said no alternative but to purchase new strap.... £850!!. Second time watch is in drawer and I am so fed up I have not even bothered to take it back again as I know what the answer will be and I cant afford to pay that again!
I need a new clasp or maybe a new bracelet so how much will this cost.
My suggestion is to take your watch to any expert watchmaker let him decide either it need clasp or new band. i hope you can get free estimate to fix this issue as well
if you are in chicago we do free estimate
hope this help
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
I have a silver/gold braided watchband and the clasp keep coming undone. Can I replace the band itself or have the clasp repaired. Marianne Wadle 515-28-50866
Your watch clasp alignment is off , that's make it lose,, most of the time i able to fix it if not then replace with new one, I hope this info helpful
from
Amfix Jewelry & Watch Repair
Chicago, IL 60601
Ph : 312 641 7000
Aug 28, 2009 • Watches
3helpful
3answers
How to fasten a Skagen watch?
Hi there. Insert the mesh strap inside the hole and secure with the hook and clip fastening with a foldover security clasp.
Hope this one helps.
3helpful
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Top watch band Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a watch band Watch Expert? Answer questions, earn points and help others
