Watches Logo
A
ALEX SMITH Posted on Sep 06, 2019
How do you undo a watch band on a raphael leon
Stuart Lomas
Level 1:
  • Contributor 27 Answers
  • Posted on Oct 06, 2019
Stuart Lomas
Contributor
Level 1:
Answers
27
Questions
0
Helped
11842
Points
40
Band or bracelet? If a band/strap it should have a buckle just like a belt. If its a bracelet it will have a clip down catch bor it will have a push button release.
I need to replace my raphael Leon watch band
if want original replacement check with manufacturer or do online search
Armitron 40/8254...how do I remove the watch strap/ band?
Hi You will need to have two screwdrivers , one to hold the one side steady whilst you unscrew the other side.
i would suggest you ask some one to hold the one screwdriver and watch will you undo the other screw.
Replace batteries on spf-40 model 2273
Looking at pictures of the watch , you will need to remove one side of the strap by undoing the screws on the side of the strap.
once you have removed one side of the strap unscrew the four screws on the case back of the watch.
then you will be able to lift the case back of the watch , it has a rubber seal on it which you need to carefull not to break.
Good luck and be carefull.
Sep 19, 2017 • The Watches
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
2helpful
I have the Timex IRONMAN Triathlon Chronograph 5G671 and the bands fit over the bezel and overlap and hold the back housing. To pop the back off and replace the battery, I'll need to remove the watch...
Yes, you have to take the bands and plastic casing part off. All screws are clearly visible. Just undo them and the parts will come off.
Nov 15, 2010 • Watches
2helpful
I bought the self adjustable bracelet watch but do not know how to adjust it to make it tighter on the wrist
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
6helpful
How do I replace the rubber watch band?
Get the screwdriver and start to unscrew all the screws relating to band and rubber casing. Then undo springbars. Then unscrew caseback screws, take out the rubber gasket, unscrew the battery contact screws and take out the battery. Buy exactly the same one and replace it, then do all the operations in the same way other way round. Rate me, please.
How do you get the battery out of the case of a Casio AMW320RD-2AV? The back unscews and I can see the #370 battery held by some sort of blue band, but how to release it?
Under that blue band is the metal clip (contact). Take the tweezers and pull a little that blue band off, then find out where the contact is clipped on and undo it by pulling legs apart.. Buy exactley the same battery and replace it. Do make sure you wonn't plase the new battery other way round.
Rate, please.
Rolex presidential watch
Check the sides of bracelet. You will notice screw ends. Undo them with watchmakers screwdriver.
Make sure screwdrivers blade is hardened steel and in perfect condition or you will damage the screw head and will not be able to unscrew it anymore.
Top watch band Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a watch band Watch Expert? Answer questions, earn points and help others
