The brew head works well when its switch is on. The steam wand produces steam, but steam also comes out of the brew head. I just descaled it and cleaned and replaced o rings.
Steam leaking from the group when the steam function is turned on:
This is normal - as there is a spring valve which stops the steam escaping normally, however if you are not using the steam wand - steam has to escape somewhere and is vented through the group.
It will not affect the steaming - but you are better to make coffee 1st and then steam the milk.
The new Dreams have endless steam - which is great for larger groups over for dinner .. When the steam button is switched off the extra steam will vent into the water tank - new models with solenoid. https://www.bluestarcoffee.eu/ascaso-dream-pid-4272-p.asp
SOURCE: Starbuck's Barista steam wand leak
remove the cover from the machine, loosen the allen screw that fastens the steam knob to the shaft, move it slightly and retighten to allow the knob to close the valve a bit more. I have had to do this a few times in the 9 years I've had my machine as either the knob loosens or the valve threads wear a bit.
SOURCE: Water leakage- V'spresso machine
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
SOURCE: breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
