SOURCE: hazard and turn signal
Under the dash is a flasher unit. Replace it and everything should start working again. The flasher unit is very inexpensive and available at most parts stores.
SOURCE: Turn signals dont work headlights dont dim heater fan doesnt work
Did all these problems happen all at one time?? If so you may have a bad body ground. Try running a electrical wire from the (-) negative side of the battery to the body and see if this works. Be sure this wire is to a place with no paint as low voltage electricity will not flow through paint.
A). If not try replacing the turn signal flasher for the turn signal problem. This is usually the culprit and it's easiest and cheapest to replace. The turn signal flasher will be found under the driver side dash next to the hazard flasher. Turn the hazard flasher one to locate it. If you want try swapping the turn signal flasher with the hazard flasher to see if this fixes it. They are the same style flasher.
If this doesn't work you may a faulty turn signal switch or some wiring issues.
B). It could as simple as the head lights bulbs need to be replaced, it's rare but I have seen when both bulbs blew at or near the same time. If your able check the voltage at the head sockets.
C). Could be a bad blower motor or switch. I'm not sure if these models have a resistor block or not. The resister block controls the electrical current going to blower motor which controls the speed of the blower fan.
SOURCE: HAZARD LIGHT DONT WORK ON 2005 HONDA CIVIC WHEN
Take your car to an autozone store. Ask them to sell you a new hazard light flasher and help you install it. They assist for free.
SOURCE: TURN SIGNAL, BRAKE & HAZARD LIGHTS
No Turn Signal Operation (blinker)The turn signal lights in your car are a basic electrical system that controls the front and rear blinker lights to alert the intended direction of the vehicle. We have listed some of the most common problems and repair troubleshooting tips below:
Troubleshooting Procedure
To start troubleshooting this problem:
SOURCE: 1998 Lincoln TC no brake or hazard lights work.
Hazard light switch... They all intermingle in operation.
My ex wifes 96TC was doing the same thing... I could OCCASIONALLY get the hazards to work by turning the hazard switch on/off like 10 times in a row and suddenly it would fix... finally bought a new switch
Testimonial: "Will try your advice, not sure were the hazard switch is (owners manual missing) so I'll call around. thanks, awa prompt."
