20 Most Recent John Deere 6300,6300l,6400,6400l Tractor Radiator Questions & Answers
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
John Deere... | Answered on Nov 15, 2018
Yikes, that sounds like an antifreeze leak. Most likely it is just a hose with a hole or crack. Lift the hood and try to see where it is coming from. One thing you must do is check the level of antifreeze or you could ruin the engine. If a red light comes on the dash, you will need to find a safe place to park and turn off the engine before it can overheat and be ruined. If you are not familiar with anything under the hood, you are best off taking it to an independent shop that has been recommended by another person.
John Deere... | Answered on Dec 02, 2014
Push you stick to press it into nutrueal if that does not work wiglle back and forth on your seat while starting your tractor to move the wheels back and forth this may be a safty mechenisim desighned into your model
John Deere... | Answered on Apr 13, 2014
White smoke means water. Check your oil for water. You may a head gasket leaking.
John Deere... | Answered on Mar 16, 2014
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
176 questions posted
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
View Most Popular
John Deere Garden
  • John Deere Garden
Most Popular Question
white smoke comeing out breather pipe
  • Garden
