Computers & Internet Logo
A
Anonymous Posted on Jul 06, 2018
Where can I find a law consultant, chief cryptographer?
1helpful
3answers
WHAT IS THE DIFFERENCE BETWEEN A DISTRICT ATTORNEY AND A COUNTY ATTORNEY?
A county attorney in many areas of the United States is the chief legal officer for a county or local judicial district. It is usually an elected position. The role of the county attorney can be similar to or complementary to that of a local state's attorney, commonwealth's attorney or district attorney.
In some jurisdictions, the county attorney oversees the operations of local prosecutors with respect to violations of county ordinances. In other jurisdictions, the county attorney prosecutes traffic matters and/or misdemeanors. In some states the county attorney prosecutes violations of state laws to the extent that the state permits local prosecution of these. County attorneys do not prosecute federal crimes, which are the jurisdiction of a United States Attorney.
Find more at the https://fnblegal.com
In the United States, a district attorney (DA) is the chief prosecutor for a local government area, typically a county. The exact name of the office varies by state.
Except in the smallest counties, a district attorney leads a staff of prosecutors, who are most commonly known as deputy district attorneys (DDAs). The Deputy who serves as the supervisor of the office is often called the Assistant District Attorney. The majority of prosecutions will be delegated to DDAs, with the district attorney prosecuting the most important cases and having overall responsibility for their agency and its work. Depending upon the system in place, DAs may be appointed by the chief executive of the jurisdiction or elected by local voters.
2answers
I have a 9M i purchased approximately 10 years ago. The weapon does not want to fire the first three rounds for the magazines. what do I need to do to get it repaired?
Suspicious!!!! A chief of police not knowing it as a 9mm or stating manufacture? Just a bit odd.that you are asking very fundimental question when if you were a trained law enforcement officer you would have the answer and if you really had a problem your department armor would be your source for answers
Jan 07, 2017 • Firearms
The router starts and finish POST then decompress image file from flash memory then shows this message: System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1) Technical Support:...
I don't really know what your asking but i guess you want to know why your startup-config doesn't load. What your router is displaying is normal. You need to change the configuration register.
1.Let the router load then if asked select Yes to abandon autoinstall, then select No to skip initial setup. Press return (enter button) when asked.
2. Now type the following at the prompts. (you type the bold stuff press enter after each command)
router>enable
router#conf t
router(config)#config-register 0x2102
router(config)#exit
router#reload
........save changes blah blah blah.. type NO
continue with reload Yes
providing you have a startup-config, the router will now load it on bootup.
Hope this helps
Pokeabeaver
ERROR 80072EFE IS NOY ALLOW TO UPDATE WINDOW 7
I understand you receive an error message 0x80072EFE when trying to installing update from the Windows Update website. This kind of issue may be caused by hardware/software firewalls or proxy server or Windows category files are corrupted. Let’s try the following steps to resolve this issue.
Step 1: Check background programs.
Disable firewalls or other Internet browser programs that can affect the Internet connection. The following programs can affect the connection to the Windows Update site and I suggest you remove or disable them:
McAfee firewall
Norton Internet Security
Zone Alarm Firewall
Panda firewall
Step 2: Delete the CatRoot2 folder
A: Stop Cryptographic Services:
1. Click Start, click Run, type in "SERVICES.MSC" and press Enter.
2. Double click Cryptographic Services, and then click Stop (if it has been started).
B: After stopping Cryptographic Service, please delete the "Catroot2" folder:
1. Locate the "C:\Windows\System32\" folder.
2. Delete the Catroot2 subfolder in System32.
Note: I am assuming your Windows Vista is installed in C:\Windows.
C: Re-start Cryptographic Services:
2. Double click Cryptographic Services, and then click Start.
After performing the above steps, please visit the Windows Update website and check the available update.
Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
